Does anyone know if its possible to remove dents from back rear section on the passenger side on corsa's
Dnt Removal
I had a dent on the rear part of the car on my Astra....thanks to a BMW X5!
I just went to a dent removal bloke and he was able to get it out. He couldn't quite get to it through the wheel arch but was able to remove the interior trim to get at it. You wouldn't even know it was there. Cost was £80.
Dentwizard or Dentmaster can more or less remove any dent nowadays as long as the paints not broken. Do a search on the net as they are nationwide.Got my previous car done and I would never of imagined they would of got the two dings out off the rear quarter on the Signum
somewhere on here is a post which shows a video of a dent being removed by first heating the panel with a hairdryer and then spraying on some kind of cold spray aerosol which causes the metal to expand and contract back into shape...im no good at finding old posts but im sure someone will help.....worth atry and save a few quid.Son of the Clyde a roaming went
Sinned aplenty, much to repent
loved and lost, gave and took
Way too lazy to write a book.sigpic
Originally posted by IanVXR View PostI think mine was just slightly closer to the door but otherwise pretty much in the same location. They should be able to remove that fine although they may have to do it from inside the car by removing the trim as mentioned above.
