Clutch Judder
  • Clutch Judder
    My corsa has decided in the mornings when it is cold to have a judder on the clutch. When you first pull off in the cold morning the car shudders. Rang Vauxhall they stated they have not had enough complaints about the problem in order to find a fix. Has anyone else had the same problem.
    You sure its not the clunking/juddering you feel through the pedels at 10mph when the ABS does the self check? Thats normal... If not i've not experianced what you mean...
    Corsa VXR Arden, 18's
      Typical vxl answer ''they have not had enough complaints about the problem in order to find a fix.''
      Surely if your complaining they should at least try and fix it for you.
        agree u would think they would say bring in we will investigate ,is it because its a vxr again "oohh dont get many of these" b******T
          still getting the juddering. i will have to ring vauxhall direct i think. Its a joke, they have your money and they dont want to know. !!!!!!
            Mate is it only when you move off first thing, happening once right at the start of your journey?
            "If you can keep your head when all around you have lost theirs, then you probably haven't understood the seriousness of the situation."
              have you got upgraded plugs?
              Rabbid Tuned - WG Motorworks
              www.wgmotorworks.co.uk
                If you insist on a test drive they would have to keep your car overnight, as you say it only happens first thing.
