Cruise control
  • Cruise control
    Hi
    Why does the cruise control light flash sometimes when attempting to use it, (no owners manaul yet)
    many thanks Colin
    You have not touched the breaks, it therefore flashes to highlight this. Touch your breaks and all will be well.
    The car needs to know the breaks work before it will allow you to use the cruise function.
      also not working under 30kph, dont press (also litle bit) brake or clutch, also not working with out gear (as some opel/vx was) etc...
        Thats a new one on me
          thanks guys
          i will get on to the dealer today to find out where my owners manaul is, it,s painful not having one
            Originally posted by Terzo282 View Post
            Hi
            many thanks Colin
            Yes mine did this yesterday, after i stopped at the services then restarted engine and entered the motorway again it worked fine.
            I had tried braking and then using it, nothing tho.
            All is fine again, strange tho
              Common on all cruise control cars that ive ever driven, it wont activate unless the brake pedal has been pressed.
              The process has to be repeated once the car has been switched off and back on.
              Go for a drive and try to use cruise before pressing the break pedal and then try it after, obviously you need to be above the 20mph limit.
                Well probably didnt notice, as the first time i brake at the end of the drive that should be it, shouldnt it ?
                  Yep that would be it.
                    Mine would not go on and i had used the brakes a few times, still wouldnt go on, light just flashed, until i had stopped to fill up fuel then when i restarted the engine and got back on motorway it worked fine.
                    First time this has ever happened.
                    That happened just after the fuel gauge did not recognise that i had filled up the stop before. The gauge slowly went up over the next 20 miles or so until it read full. Weird!!
