my spanner light has came on and the car has no power anymore i had a courtney panel filter a venturi dump valve and a boost gauge on will this of affected it?? iv taken it all of and its booked in for 2moro is there any way they would be able to tell that iv done anything to it or will the warrenty be ok as im a bit worried. thanks
spanner light??
Originally posted by farrell123 View Postno mate drives fine but just like a 1litre corsa dont think it will go above 4500 revs and i think theres a strange noise coming from the turbo. you think the warrenty should be fine?
Yes, if you didn’t oil it there should be not sign, but the oil is needed to filter effectively so it maybe the course of you problem.
But if you have put everything back to standard and put the original panel filter back in I cant see how they could tell
first of all, you have voided the warranty on your car by using an aftermarket filter, 2nd you have a dump valve, and thirdly its as mentioned probably the amm or boost solenoid. IF you have put the car back to standard they probably wont know BUT you have admitted to decpetion on a vx forumsigpicGONE BUT NOT FORGOTTEN!
