Help - think I over filled the oil.
  • Help - think I over filled the oil.
    Couple off nights back oil light came on whilst driving, pulled over checked the dip stick - in poor light dip stick looked empty - put a litre of Mobile 0 40 in.
    Checked it again this morning and the dip stick is showing level max.
    Car seems to be running smooth no wiffs of burning oil.
    Have I foobarred the CAT ? - if so how much will it cost.
    Cheers,
    OS.
    its ok if its on the max level, can you see if its gone over the max level?
    CORSA VXR
      You should be OK, so long as its not way over, it could cause contamination of the Cat but I think you would be unlucky. Overfilling can also blow oil seals.
      If your going to add some oil its always best to fill a 3rd of a litre at a time then recheck the level after a few mins, I hope you didn't add a litre in one go?
        level on the Max but not over - filled half then half - as it looked dry on the stick
          from the bottom of the dipstick to max is approx 1 litre of oil so you should be fine !
            yeah also know that from MIN to MAX level on stick shut be 1L...
