TID Question....
  • TID Question....
    Was sat in an sri demo yesterday, which had the graphic info display in it (the one you get with climate or bluetooth) and noticed it shows all the ecu information like fuel range etc....
    I am guessing that the triple info dislpay, the smaller one, does not show any of this info on a vxr??
    And is there a way to retrofit the bigger screen??
    Sorry if this sounds like a dumb question
    Astra Edition #105
    It shows it where the milage is. Think ul need to upgrade to get the bigger screen,
    Rabbid Tuned - WG Motorworks
    www.wgmotorworks.co.uk
      thnx james....do u have the smaller display?
      what else does it show?
      Astra Edition #105
        i got the smaller screen but want a bigger screen, was wondering if this is possible???
          i thinkg that those info you shut have also with the small one, but just with BC - then those you can see between speedo and rpm...
            PM Sent
              What did this PM say? I would like to know also!
              I thought it was tough because you needed climate control with electronically operated all the heating stuff and if you haven't got this then it's old fashioned cables.
                bluetooth gets you the big display as well cos I have it yet no climate control
                  Originally posted by VX Tech View Post
                  PM Sent
                  What did this PM say? Can the bigger screen be retrofitted?
                  If so any ideas how much the unit is?
                  Corsa VXR Arden, 18's
                    yes both the GID and CID can be fitted. however you will need a new surround for the screen.
                    Tech2 Diagnostics
                      Surround is cheap from what ive been told...
                      Will it need marrying? Or is this just if I want it to work with stereo? What if using aftermarket stereo?
                      Any ideas how much the non sat nav screen is?
                        i have the big screen it shows radio and when you play an mp3 cd or somthing off itunes it gives the track name although i don't know if thats standard on all corsa's, phone which shows network signal strength and you can add your phone book and it has voice activasion, the bc shows your average mpg how many miles to refill and the mpg your doing at that point if you press the bc button again it will show more info about short and long distance average mpg's etc and theres also a stopwatch for track days
                        this is mainly controlled using the steering wheel controls so unless you have them i presume you would have to add them aswell if you upgrade you centre console screen
                        Corsa VXR now sold
                          yes the unit will need marrying and the old one devorcied from the car
                          think the GID is about £200 ish
                          Tech2 Diagnostics
                            Ah, okay. Didnt think about the steering controls. We all have them but with small screen it controls the mpg etc info on the main dash including stop watch etc... so th steering controls would be talking to the wrong thing!!! LOL
                            Maybe this is where Tech Two comes in?
                              Jesus, that much?
