heres a question? SRi vs vxR
  • heres a question? SRi vs vxR
    duno if this been threaded b4 but has the corsa SRi 1.6T got the exact engine as the vxR?
    Was discusing it with my felow vauxhalian workmate n he thinks the vxR must have something difrent ie injectors to have the extra 40bhp?
    Were as i think its identicle just running a diffrent map? So in theory you could have the SRi running like a vxR..minus the brakes and suspension!
    So i thought id grill you lot... Any ideas?
    After speaking to John Thorne he assures me the engines are identical. The ECU is the only differing factor as far as BHP & torque is concerned. He also went on to say that with a simple remap you can have VXR performance with cheaper insurance costs. (Haven't looked into insurance so don't know).
    But as far as I can see, if your going to modify the suspension, brakes, exhaust and interior any way then personally I don't see a reason to purchase a VXR. Just my opinion of course.
      i am sure it has different intake manifold + exhaust, also diff remap on ecu.
        Does the SRi have the 6 speed or 5 speed gear box?
        Clique #14
          think have also 6 gears.
            from what i believe its the same but the vxr has a remap
              This cant be true because if its the same engine and just the fact that the sri is a lower map, tunners should be able too make better gains with an sri. I think internals are different too.
              Rabbid Tuned - WG Motorworks
              www.wgmotorworks.co.uk
                Is it a differnet Turbo? Like Z20LET/Z20LER have different turbo's from the Z20LEH
                Clique #14
                  The sri has the same turbo / same gearbox/ engine as the vxr / astra 1.6 turbo / meriva vxr, just a different map. What a qcar once tuned.
                  www.courtenaysport.co.uk
                  for all your tuning needs.....
                  01692 404313.
                    There isn't much in the price once you add the VXR styling pack to it..
                    Clique #14
                      i know of one sri on corsa d forum but it doesnt make the same power as a tuned vxr?? so why cant a tuned sri make the same power as a tuned vxr then
                        because of business strategy
                        how do you know that sri can not be tuned to same power as vxr ???
                          SRi:
                          http://www.superchips.co.uk/curves/CorsaSRi16T150.pdf
                          VXR:
                          http://www.superchips.co.uk/curves/CorsaVXR.pdf
                          3 BHP and about 30 Nm less... not so bad i think
                            im not saying it cant but i havent seen one as of yet
                              so you can tune it to just like the vxr? cause i not heard it being done yet, you see my point?
