Tyre pressure light
  • Tyre pressure light
    Wont turn off!!
    Any idea why this warning light wont turn off?
    lol and before you ask, YES, i have put more air in the tyres.
    Originally posted by DAIR View Post
    Wont turn off!!
    Have you pressed and hold the DDS light mate to reset the system?
    Corsa Has Left The Building
      Never knew i had to hold it down. i'll give that a try.
      thanks
        Now give me some REP for being helpfull
          Maybe shouldnt abbreviate REP as report and reputation are next to each other Is it possible to see your reputation 'score' ?
          "If you can keep your head when all around you have lost theirs, then you probably haven't understood the seriousness of the situation."
            i was gona tel him that! (hold it down) but ya beat me 2 it.
            I want rep! Reputation not reportin
              I had this the other week! **** my self! Wondered what the light was.. Re-Set the DDS and all is fine!
                Lets have a 'how to' on how to reset start to finish.
                  http://www.vxronline.co.uk/forum/showthread.php?t=33556
                    GFS....... Dont ask for help on the forum, just RTFM....
                      If you go to your User CP screen, if anyone has left you any Reputation points, you'll see them there
                        The valves on the 17" wheels are normal rubber type but on the 18's they are metal does this make any difference with the pressure monitoring? Not sure how it works on the corsa.
                        CORSA VXR
                          Its wheel rotation monitoring not pressure. You set the pressure and reset the DDS button on the dash it then monitors for one wheel rotating different to the others...
                          Corsa VXR Arden, 18's
                            Hmmm... if you were unlucky enough to get four punchers all deflating at the same rate the warning wouldnt go off presumeably... LOL
                              Oh I see, so it's done by the wheel speed sensor in abs module? So low pressure = slower wheel rotation?
                              CORSA VXR
