vxr spare wheel
  • vxr spare wheel
    i want some sort of spare wheel when i go on longer trips (dont trust the gunge stuff) so "1" dose the space saver from a normal corsa fit or "2" dose a steel rim and tyre off a normal corsa fit. thanks
    already few thready here about that... but still dont heart about somebody who have spare tyre in car (including the small one - space saver)
      Dont forget a jack and wheel brace
      Mods: Carbon wrap bonnet, carbon wrap roof, carbon diffuser, clifford, boost gauge, Wind deflectors, tints, TD 1.2s with R888 rubber ready for the summer, RARB and braces!
      Future mods: springs....
        Then the problem is at your front skirt, you'll crack the skirt with a normal jack! I promise you that!
          will a jack from a vauxhall dealer work ok
            the 16" space saver from an astra or a vectra will fit over the brakes and does the job perfectly
              There isnt a jacking point for a standard jack.
                yeah read the handbook, says dont use a jack on vxr's, might just buy a brand new wheel from dealer so AA could fit it at roadside (they'll have trolley jack?).
                  check here http://www.vxronline.co.uk/forum/sho...t=15278&page=3
                  Deg
                    stick in a 19 mate
                      Basically NO!!!!! You will need a scissor jack (I've got a Draper 1.5tonne Scissor Jack , stock no:- 87433, part no SJ2A) I've also got a full size spare wheel. This does take up a lot of space. I got a an extending brace from LIDL.
                      Arden Blue Corsa VXR , 18" anthracites, Quaife LSD, AP VXRacing 4pot brakes, KW Variant3 (40mm drop) & Uprated Fast Road Geometry Setup, larger intercooler, 3" Nurburgring exhaust conversion, ITG panel filter, Nurburgring front & back splitters, colour coded roof rails
                        stick in a 19 mate
                        no well on my arctic
                          aghhh corsa sorry
                            Originally posted by DEG VXR View Post
                            Hi GAZ1, Check the link above as DEGVXR says. I have a spare saver as the link info says & have had to use in anger, no probs. All the info is there.
                            Hoggy.
                              Hoggy.
                              great hoggy, got the jack now going to get space saver and tyre. thanks for info everybody, gaz
