Vacuum Hose size
  • Vacuum Hose size
    Hi guys,
    Does anyone know the size of the vacuum pipe used in the corsa vxr??
    many thanks
    if you mean from the dv to the fuel reg point it 4mm ID (internal diameter).
    Thats for a bailey anyway but i presume others probley the same.
      would a 5mm make much diff with a tight cable tie around?
      Arden corsa Vxr = TMS stage 2=(227.8BHP)
        no not realy because the other end were you T it off is 4mm. You might get away with it but will look untidy imo.
          thanks for the answer anyways mate
