Rtfm !
  • Rtfm !
    Just as I know that some ppl here don’t reading manual, today I saw one guy on busy road junction during change punctured tire – hopefully he had spare one.
    That is advice for all ppl with „repair kit“ instead or spare wheel (all Corsa owners), as I think is better to know what to do (read the manual at quiet home – and look what I will be doing) with repair kit, as than read manual on some busy road junction or on highway at night during snowfall...
    good advice, i thought u would just plug the cannister into the valve and let the gunk flow into the tyre .... am i wrong?
      Squeeze the stuff in then pump up the tyre, doesnt work though
      "If you can keep your head when all around you have lost theirs, then you probably haven't understood the seriousness of the situation."
        if the whole is bigger than a 5mm slash it will just flow out as fast as you put this in, found out the hard way when i hit a dropped drain cover and got a puncture in the middle of London at 2am
        Tyre weld is useless for big punctures/blowouts unless you run over a nail, idea is you leave the nail in and put the tyre weld in.
        Best thing to do is try and source a spare wheel sure somebody on here has done that, remember you will also need a wheel nut bar and a trolley jack!
          yes, it shut be like that, but just to check if to connect "A" to "B" than to "C" or if i have to first put C to B and just than A... and also when you open the all "repair thinks" - sometimes you are not sure if you have something OK or upside down... also that the compressor shuldt be running more that 15 minutes as i know - how you want to put the gunk flow to tyre with burned compressor ? or make some pressure with burned compressor ?
            Jack the car up first then fill with gunk id have thought??
              did you find in corsa jack ?
                Hang the front of the car over a cliff edge, that will get the wheels off the ground (not recommended)
                  and what to do when you have puncture on rear wheels ?
