Camber
  • Camber
    Has anyone had theirs tweeked?
    I'll assume you mean suspension/wheel camber? Someone will correct me if i'm wrong here but it can not directly be changed. Only adjustted by changing the toe in/out... I used to be -80mm lower on my old corsa and the only way of setting it up was with camber adjustting bolts in the damper bases... Or adjusttable top mounts that end up costing the earth...
    Have things changed since then?
    Why are you concerned? Is it lowered?
    Corsa VXR Arden, 18's
      That is what i meant my tweek.
      Im having it lowered soon.
      Aussie tells me that the Corsa's standard setup, allows negative camber.
