Best engine oil
  • Best engine oil
    Just wondering what oil people use for there VXR. Courtney recommend Valvoline 5w 40.
    I use 5/30 in mine from vauxhall
    xbox addy -turboyoda85
    Instagram yoda_craig85
      Use anything that's the right grade/spec.
      Brand/being the most expensive isn't important...you only need to go that route with gearbox oil IMO.
      I usually go with ECP's Triple QX if its on deal, although last time i got 5 litres of Shell for £30 at Halfords which was cheaper.
        When I had my car mapped at RnD they recommend using Millers 10w40 but that’s all dependant on what mods your car is running and map etc that’s just what they recommended to me.
        Which I am at the end of this month doing my first oil change as I’ve nearly done 5k in her.
        but like people have said as long as it’s a suitable grade for your car then make or price is pretty insignificant,
          Cheers all. Its always had 5w 30 so ill continue with that. I work for Vauxhalls so i get good discounts on parts.
            You work for Vauxhall? Why arent you asking the actual manufacturer instead of strangers on the internet? 😂😂😂
              Cause you guys probably know more. Mines running a Courtney stage 2 does that make any difference on oil grade.
