hiya what is water injection? i noticed the greek corsa have it on stage 4 but what is it?? cheers
water injection?
Originally posted by wild cars View PostWater injection is a seperate system that will spray water, and sometimes Water/Meth into the intake, this works like an intercooler, but immediately and drastically reduces the intake temp. Which increases power...
is well working on aircrafts already long timeMB E63s AMG
any system you like :P injecting nitrous causes extreme amounts of cooling even compared to water injection, and the extra oxygen is even more power, although this wont last long at high boost as a fail safe.
I'm still confused why you would want to apply this technology to a corsa VXR, the turbo must be absolutely maxed out to be pinking, unless the turbo used is too big for the engine :/ or just bad cooling
Originally posted by Deaniscool125 View PostI'm still confused why you would want to apply this technology to a corsa VXR, the turbo must be absolutely maxed out to be pinking, unless the turbo used is too big for the engine :/ or just bad cooling
Only good is that...! It can be used on stock turbo too with no worries!
If you raise the advance through the new maps you will need those extra Octanes that the water/meth gives you...!
Its a must for extreme tuning stages...!!Last edited by gk002; 29 September 2009, 02:30 PM.
