handbrake prob
  • handbrake prob
    Does anybody have any info on the handbrake adjustment on the corsa vxr? its not holding either wheel so need to know how to adjust or should i just book it in ?
    check some of those:
    http://www.vxronline.co.uk/forum/showthread.php?t=12796
    http://www.vxronline.co.uk/forum/showthread.php?t=17983
    http://www.vxronline.co.uk/forum/showthread.php?t=18679
      sounds like the calipers hav siezed, get it to vaux as the pistons inside wil be siezed solid
        You can adjust the handbreak by pulling the handbreak gaitor up and underneath theres a 10mm nut on the cable, Which you can either tighten or loosen.
        Hope that makes sense
        Arden Corsa VXR
          thanks for your reply, had someone pumping the brake while spinning back wheel and they locked instant, pull up handbrake one side works the other won't, pull up handbrake clicks loud ......read a few things about this stuff lucky my drive aint slanted..... seems like a trip to vauxhall, only a year old poor baby
            Cheers tried that no good
              the nut under the handbrake, will this make it have less play when you pull the handbrake up? i stupidly tried handbrake turning and since it hasnt been as tight as it was lol
                I'd get it booked in and looked into mate.
                Rabbid Tuned - WG Motorworks
                www.wgmotorworks.co.uk
                  Booked it in both calipers need replacing, thanks for all your replys
                    Sorry but the first thing i would have done with a year old car still under warrenty is get it booked into the dealers, not asked how to do it myself, because if you had 'done it wrong' your warrenty would have been void,
                    Thats what warrenty is for, just my opinion.
                      see above..
