error code list and how to access it?
  • error code list and how to access it?
    hiya, done a search but couldnt find anything, is there a list for all the error codes when the spanner light comes on? and how do you show which numbers it is? i think its something like press the accelerator and brake and turn on ignition? any help?
    Error Codes 1
    brake and accelerator then turn key to 2nd stage....do not turn ignition on!!
    B0132 battery voltage high C-123
    B0132 low battery voltage C-123
    B0158 outside temperature sensor voltage is too small DIS (Information Display) C-015
    B0158 outside temperature sensor circuit voltage to open or big DIS (Information Display) C-015
    B0283 rear window heater malfunction heating, ventilation and air conditioning B-015
    B1000 replace the control unit - EEPROM errors C-002
    B1000 replace the control unit - hardware errors C-002
    B1000 control device to replace C-002
    B1000 control device malfunction C-002
    B1001 airbag control unit is not locked hardware and software B-003
    B1001 vehicle identification number is not programmed hardware and software B-005
    B1001 error programming hardware and software B-003
    B1001 Linkslenker-/Rechtslenker- configuration errors C-002
    B1001 control device is not calibrated hardware and software B-003
    B1001 control device is not programmed hardware and software B-003
    B1001 control device programming hardware and software B-003
    B1001 variants code is not programmed hardware and software B-004
    B1001 variant configuration is not programmed hardware and software B-003
    B1006 control device to replace C-002
    B1009 control device programming hardware and software B-003
    B1016 vehicle identification number is not programmed hardware and software B-005
    B1019 control device in the extradition state C-002
    B1325 system voltage power too large B-003
    B1325 system voltage power too small B-003
    B1375 Geschaltete system voltage (A ignition) is not plausible with CAN signal B-005
    B1385 terminal 15A dysfunction B-004
    B1390 comfort closure circuit voltage power too small windows C-009
    B1395 engine runs too small signal voltage EHPS (electro-hydraulic auxiliary power steering) C-003
    B1420 power supply voltage is too large C-124
    B1420 power supply voltage too small C-124
    B1421 supply voltage signal is not in the target area C-124
    B1428 relay starters dysfunction C-127
    B1441 Geschaltete system voltage (Ignition A) Power too big C-125
    B1441 Geschaltete system voltage (ignition ON) voltage too small C-125
    B1451-voltage relay equipment too large or open circuit C-106
    B1451 accessories relay circuit voltage is too large C-106
    B1453 Geschaltete system voltage (Ignition A) Power too big C-125
    B1453 Geschaltete system voltage (ignition ON) voltage too small C-125
    B2961 position ignition key switch circuit malfunction C-002
    B3601 holding magnetic key relay circuit malfunction AF 17-4 Automatic 4-speed gearbox C-005
    B3644 switch channel high wheel remote stuck RQ (Entertainment Head Unit) C-012
    B3644 switch channel high wheel remote control circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3645 channel down button remote control wheel stuck RQ (Entertainment Head Unit) C-012
    B3645 switch channel down steering wheel remote control circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    Scrolling right B3646 wheel stuck RQ (Entertainment Head Unit) C-012
    Scrolling right B3646 wheel circuit open RQ (Entertainment Head Unit) C-012
    Scrolling right B3646 wheel circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3647 switch voice remote control wheel stuck RQ (Entertainment Head Unit) C-012
    B3647 switch Voice Control wheel remote resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3648 switch telephone wheel remote stuck RQ (Entertainment Head Unit) C-012
    B3648 switch telephone wheel remote resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3649 Scrolling left wheel stuck RQ (Entertainment Head Unit) C-012
    B3649 wheel Scrolling left open circuit RQ (Entertainment Head Unit) C-012
    B3649 Scrolling left wheel circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    C0252 control device in the extradition condition or defect hardware and software B-003
    Wrong C0550 configuration variations programmed control unit or defective hardware and software B-003
    C0550 control device to replace C-002
    C0550 control device is not programmed hardware and software B-003
    C0551 vehicle identification number is not programmed hardware and software B-005
    Wrong C0551 variant configuration programmed hardware and software B-004
    C0551 control device programming hardware and software B-003
    C0551 variants code is not programmed hardware and software B-004
    C0551 variant configuration is not programmed hardware and software B-004
    False C0569 system hardware configuration and software B-003
    C0800 system voltage power too large B-003
    C0800 system voltage power too small B-003
    C0920 control device is not programmed hardware and software B-003
    C1523 system voltage power too large C-105
    C1523 system voltage power too small C-105
    C1550 control device to replace C-002
      Error codes 2
      P0070 sensor ambient air temperature dysfunction B-024
      P0100 air mass / volume knife dysfunction C-007
      P0100 air mass / volume knife signal too large C-007
      P0100 air mass quantities too small knife signal C-007
      P0100 air mass meter error
      P0105 intake manifold pressure sensor voltage error
      P0110 intake sensor signal is too large C-008
      P0110 intake sensor signal to small C-008
      P0110 Ansauglufttemperaturfühler error
      P0110 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
      P0115 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
      P0115 coolant temperature sensor errors
      P0115 engine coolant temperature sensor is not in the target area cooled engine C-002
      P0115 engine coolant temperature signal is too large cooling engine C-002
      P0115 engine coolant temperature signal is too small engine cooling C-002
      P0120 throttle valves / pedal position donor "A" is not a target area C-005
      P0120 throttle valves / pedal position donor "A" signal is too large C-005
      P0120 throttle valves / pedal position donor "A" signal to small C-005
      No P0130 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-020
      P0130 lambda probe dysfunction (Bank 1 Sensor 1) B-020
      P0130 lambda sensor circuit not in the target area (Bank 1 Sensor 1) B-025
      P0130 O2 sensor circuit voltage high (Bank 1 Sensor 1) C-019
      P0130 O2 sensor circuit voltage low (Bank 1 Sensor 1) C-019
      P0135 lambda probe heating dysfunction (Bank 1 Sensor 1) B-012
      P0135 lambda probe heating open (Bank 1 Sensor 1) B-028
      P0135 lambda probe heating voltage is too big (Bank 1 Sensor 1) B-012
      P0135 lambda probe heating voltage is too small (Bank 1 Sensor 1) B-012
      No P0136 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-027
      P0136 lambda probe dysfunction (Bank 1 Sensor 2) B-027
      P0136 lambda sensor circuit not in the target area (Bank 1 Sensor 2) B-026
      P0136 O2 sensor circuit voltage high (Bank 1 Sensor 2) C-023
      P0136 O2 sensor circuit voltage low (Bank 1 Sensor 2) C-023
      P0141 lambda probe heating dysfunction (Bank 1 Sensor 2) B-013
      P0141 lambda probe heating open (Bank 1 Sensor 2) B-029
      P0141 lambda probe heating voltage is too big (Bank 1 Sensor 2) B-013
      P0141 lambda probe heating voltage is too small (Bank 1 Sensor 2) B-013
      P0170 fuel correction dysfunction (Bank 1) B-016
      P0180 fuel temperature sensor short-circuit/interruption
      P0190 Mechanical fault in the fuel system failure
      P0195 ضltemperaturfühler error (at Y17DT and Y17DTL not VERBAUT!)
      P0201 cylinder 1 injector signal too large B-011
      P0201 cylinder 1 injector signal to small B-011
      P0201 cylinder 1 injector circuit open B-011
      P0202 cylinder 2 injector signal too large B-011
      P0202 cylinder 2 injector signal to small B-011
      P0202 cylinder 2 injector circuit open B-011
      P0203 cylinder 3 injector signal too large B-011
      P0203 cylinder 3 injector signal to small B-011
      P0203 cylinder 3 injector circuit open B-011
      P0204 cylinder 4 injector signal too large B-011
      P0204 cylinder 4 injector signal to small B-011
      P0204 cylinder 4 injector circuit open B-011
      P0216 Einspritzbeginn error
      P0219 engine speed is too large C-025
      P0220 throttle valves / pedal position donor "B" is not in the target area C-005
      P0220 throttle valves / pedal position donor "B" signal is too large C-005
      P0220 throttle valves / pedal position donor "B" signal to small C-005
      P0230 fuel pump primary circuit signal is too large B-010
      P0230 fuel pump primary circuit signal to small B-010
      P0235 boost pressure signal to donors large C-031
      P0235 boost pressure donor signal too small C-031
      P0243 boost pressure valve voltage too large C-032
      P0243 boost pressure valve voltage is too low C-032
      P0243 boost pressure valve open circuit C-032
      P0251 overflow valve / pump control unit dysfunction (99% pump control unit died)
      Several P0300 cylinder misfire detected B-021
      P0301 cylinder misfire detected 1 B-021
      P0302 cylinder misfire detected 2 B-021
      P0303 cylinder 3 misfire detected B-021
      P0304 cylinder misfire detected 4 B-021
      P0313 misfire at low fuel levels detected B-021
      P0325 Klopfsensor 1 signal too big (bank or individual sensor 1) B-022
      P0325 Klopfsensor 1 signal too small (bank or individual sensor 1) B-022
      P0335 crankshaft sensor wrong signal C-002
      P0335 crankshaft sensor no signal
      P0335 crankshaft sensor signal is not in the target area C-002
      P0340 engine speed error '
      P0340 camshaft position donor dysfunction C-009
      P0340 camshaft position encoder signal to big C-009
      P0340 camshaft position encoder signal to small C-009
      P0340 camshaft position encoder circuit open C-009
      P0340 camshaft sensor signal is not in the target area C-009
      P0370 pumps position signal void
      P0380 Vorglühanlage short-circuit/interruption
      P0381 Glühzeitkontrolleuchte short-circuit/interruption
      P0400 EGR valve errors
      P0420 catalyst efficiency under limit (Bank 1) B-017
      P0441 tank vent system wrong tank vent River B-014
      P0443 fuel tank vent valve open District B-014
      P0443 fuel tank vent valve voltage high B-014
      P0443 fuel tank vent valve voltage low B-014
      P0460 fuel level sensor signal is not in the target area IPC (instrument) B-012
      P0480 cooler fan (small) short-circuit/interruption
      P0481 cooler fan (big) short-circuit/interruption
      P0500 vehicle speed signal is not in setpoint range B-023
      P0500 distance frequency (employer) error (comes from ABS unit)
        error codes 3
        P0501 vehicle speed signal is not in setpoint range B-023
        P0505 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P0505 idling regulator short-circuit/interruption
        P0520 engine oil pressure switch / sensor is not in the target area IPC (instrument) C-018
        P0530 air conditioners misprint
        P0530 air conditioners pressure sensor signal is too large heating, ventilation and air conditioning C-009
        P0530 air conditioners pressure sensor signal is too small heating, ventilation and air conditioning C-009
        P0560 battery voltage error (over or under voltage)
        P0560 system voltage dysfunction C-110
        P0560 system voltage outside Area C-110
        P0560 system voltage power too large C-109
        P0560 power system voltage too small C-109
        P0560 system voltage too high C-110
        P0560 system voltage is too low C-110
        P0560 supply voltage too high C-110
        P0571 Bremslichtschalter short-circuit/interruption
        P0571 switches brake malfunction exterior lighting / flasher Appendix B-014
        P0601 control device to replace C-002
        P0602 vehicle identification number is not programmed hardware and software B-005
        P0602 injector volume adjustment is not programmed hardware and software B-015
        P0602 tires extent not programmed hardware and software B-003
        P0602 Security code is not programmed hardware and software B-003
        P0602 Control Unit C-002 program
        P0602 control device programming hardware and software B-003
        P0602 ECUs programming errors (lack of out-of-code programming or index)
        P0602 variant configuration is not programmed hardware and software B-004
        P0603 ECU EEPROM errors C-002
        P0603 control device to replace C-002
        P0604 controller error - RAM C-002
        P0605 EPROM errors C-002
        P0605 control device to replace C-002
        P0606 controller replace error (Worst Case - Total damage control unit)
        P0606 control device malfunction C-002
        P0606 controller re-initialization C-004
        P0606 system voltage too high C-110
        P0607 Klopfsensor circuit malfunction B-022
        P0607 Klopfsignal module; control device to replace B-022
        P0607 controller replace error (see above)
        P0610 control device programming hardware and software B-003
        P0615 starter relay circuit open C-127
        P0615 Amplifier starter relay temperature too large C-127
        P0615 starters voltage relay too large C-127
        P0615 relay starters voltage too small C-127
        P0621 generator control lamp arrangement dysfunction IPC (instrument) C-021
        P0650 CAN bus no communication with CIM (Steering Column module) C-003
        P0650 error display control light (MI) dysfunction IPC (instrument) B-008
        P0703 Brake lamp switch error
        P0704 clutch switch error
        P0704 clutch switch dysfunction CRC (electronic speed control) B-010
        P0725 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P0725 engine speed error '
        P0815 switches High Turn the steering wheel remote stuck C-002
        P0815 switches high wheel remote switching circuit resistance not in the target area C-002
        P0816 switches Runterschalten wheel remote stuck C-002
        P0816 switches Runterschalten wheel remote control circuit resistance not in the target area C-002
        P1100 Critical System Error Error
        P1105 Barometrischer pressure sensor short-circuit/interruption
        P1105 pressure sensor signal Barometrischer too large C-030
        P1105 pressure sensor signal Barometrischer too small C-030
        P1106 boost pressure donor signal is not in the target area C-031
        P1110 vacuum tube switching valve errors
        P1120 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P1120 pedal sensor 1 short-circuit/interruption
        P1120 pedal sensor 1 signal to high C-004
        P1120 pedal sensor 1 signal too low C-004
        P1120 pedal position sensor 1 and 2 false signal ratio C-004
        P1122 pedal sensor 2 short-circuit/interruption
        P1122 pedal sensor 2 signal to high C-004
        P1122 pedal sensor signal is too low 2 C-004
        P1125 boost pressure solenoid valve errors
        P1173 Einspritzmengenbegrenzung because Oeltemperatur error
        P1180 fuel temperature sensor errors
        P1195 ضldruckschalter short-circuit/interruption
        P1220 Einspritzdauer monitoring error
        P1230 main relay dysfunction power supply and communication C-013
        P1243 turbocharger bypass solenoid valve voltage too large C-033
        P1243 turbocharger bypass solenoid valve voltage too small C-033
        P1243 turbocharger bypass solenoid valve open circuit C-033
        P1243 turbocharger bypass valve not in the target area C-033
        P1335 engine speed signal error
        P1345 cam shaft speed error
        P1481 fan control circuit open 1 engine cooling B-004
        1 fan P1481 control circuit voltage engine cooling too large B-004
        1 fan P1481 control circuit voltage too small engine cooling B-004
        P1482 fan control circuit open 2 engine cooling B-004
        P1482 fan control circuit voltage 2 too big engine cooling B-004
        P1482 fan control circuit voltage 2 too small engine cooling B-004
        P1483 fan control circuit open 3 engine cooling B-004
        3 fan P1483 control circuit voltage engine cooling too large B-004
        3 fan P1483 control circuit voltage too small engine cooling B-004
        P1490 additional coolant pump circuit open B-015
        P1490 additional coolant pump circuit voltage is too large B-015
        P1490 additional coolant pump circuit voltage too small B-015
        P1500 electronic throttle author dysfunction C-006
        P1501 immobiliser coding errors
        P1502 immobiliser error
        P1503 immobiliser signal error
        P1515 donor pedal position error
        P1523 throttle author is not in the target area C-006
        P1526 throttle author lower position not learned C-006
        P1530 high voltage relay climate heating, ventilation and air conditioning B-016
        P1530 low voltage relay climate heating, ventilation and air conditioning B-016
        P1530 air conditioning requirement error
        P1530 air conditioning relay circuit open heating, ventilation and air conditioning B-016
        P1540 Climate pressure signal short-circuit/interruption
        P1560 battery voltage error
        P1560 Geschaltete system voltage (Ignition A) signal dysfunction (CAN) C-109
        P1565 interface speed control dysfunction CRC (electronic speed control) B-006
        P1600 engine torque is not plausible B-030
        P1600 control device to replace C-002
        P1600 controller error
        P1601 temperature controller error
        P1602 Maximum speed is not programmed hardware and software B-003
        P1602 programmers / Replace control unit (SG) hardware and software B-003
        P1602 control device programming hardware and software B-003
        P1602 variant configuration is not programmed hardware and software B-003
        P1603 control device to replace C-002
        P1604 programmers / Replace control device
        P1604 control device to replace C-004
        P1606 engine torque is not plausible B-030
        P1606 control device to replace C-002
        P1610 immobilizer anti-theft function is not programmed B-009
        P1610 immobiliser dysfunction Immobilizer B-009
        P1610 immobilizer function programming error
        P1611 Wrong security code error
        P1611 Wrong security code immobiliser B-015
        P1612 immobiliser signal error
        P1613 immobiliser no signal or wrong signal Immobilizer B-008
        P1613 immobiliser signal error
        P1614 Wrong transponder key error (the chip is still in the key?)
        P1614 Wrong transponder immobiliser key B-006
        P1614 immobilizer anti-theft wrong signal B-008
        P1615 ECM (engine control unit) Identification failed Immobilizer B-006
        P1616 CIM (Steering Column module) wrong environment indicator Immobilizer B-006
        Replace P1620 controller error
        P1625 relay power supply fault
        P1630 Kraftstoffeinspritzmenge error
        P1631 controller error injection pump
        P1635 Vorglühanlage error
        P1650 CAN error
        P1651 CAN error
        P1660 fuel Abschaltventil error
        P1680 coolant temperature output short-circuit/interruption
        P1690 control lamp voltage error
        P1694 control lamp voltage error Glühzeit
        P1811 engine torque signal malfunction ABS / TC / ESP (vehicle dynamics system) C-011
        P1814 Invalid signal of ECC (Electronic air conditioning) ECC / SAC (Electronic climate control) B-028
        P1895 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P1896 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P2638 control device to replace C-002
          error codes 4
          U0001 CAN bus maximum configuration list is not programmed hardware and software B-003
          U0009 CAN bus communication nodes no C-005
          U0101 CAN bus, no communication with gearbox control unit C-003
          U0121 CAN bus no communication with ABS / TC C-003
          U0140 CAN bus no communication with CIM (Steering Column module) C-003
          U2100 CAN bus dysfunction C-005
          U2100 CAN bus communication dysfunction C-005
          U2100 CAN bus communication errors C-005
          U2100 No communication with CAN-bus (High Speed) C-005
          U2100 No communication with CAN-bus (Low Speed) C-005
          U2100 No communication with CAN-bus (Mid Speed) C-005
          U2101 CAN bus (High Speed) maximum configuration list is not programmed hardware and software B-003
          U2101 CAN bus (Low Speed) maximum configuration list is not programmed hardware and software B-003
          U2101 CAN bus (Mid Speed) maximum configuration list is not programmed hardware and software B-003
          U2101 CAN bus maximum configuration list is not programmed hardware and software B-003
          U2102 CAN bus (Mid Speed) maximum configuration list is not complete hardware and software B-003
          U2103 CAN bus communication nodes no C-005
          U2103 CAN bus Rücksetzzنhler overflow C-005
          U2103 CAN-bus circuit malfunction C-005
          U2103 No communication with CAN-bus (High Speed) C-005
          U2103 No communication with CAN-bus (Low Speed) C-005
          U2104 CAN bus (High Speed) Rücksetzzنhler overflow C-005
          U2104 CAN bus (Mid Speed) Rücksetzzنhler overflow C-005
          U2104 CAN bus Rücksetzzنhler overflow C-005
          U2105 CAN bus, no communication with the engine control unit Fahrzeugbezogene Prüfanleitung B-019
          U2105 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
          U2106 CAN bus, no communication with gearbox control unit C-003
          U2106 CAN bus, no communication with TCM (automatic transmission control unit) C-003
          U2107 CAN bus no communication with CIM (Steering Column module) C-003
          U2107 CAN bus no communication with IPC (instrument) C-003
          U2108 CAN bus, no communication with ABS (anti-) C-003
          U2108 CAN bus no communication with ABS / TC C-003
          U2108 programmers / Replace control unit (SG) hardware and software B-003
          U2110 CAN bus no communication with ABS / ESP C-003
          U2111 CAN bus no communication with EPS (Electronic Power Steering) C-003
          U2112 CAN bus, no communication with CDC "> CDC"> SADS (Part Active damping system) C-003
          U2112 CAN bus No communication with CDC (electronic damper control) C-003
          U2113 CAN bus not communicate with SDM (airbag) C-003
          U2113 CAN bus not communicate with SDM (Sensing and Diagnostic Module, airbag) C-003
          U2116 CAN bus no communication with IPC (instrument) C-003
          U2117 CAN bus, no communication with DIS (advertisement) C-126
          U2117 CAN bus, no communication with Info-Display C-126
          U2120 CAN bus, no communication with AHL (headlamp control) C-003
          U2127 CAN bus, no communication with ECC (Electronic Climate) C-003
          U2139 CAN bus no communication with CIM (Steering Column module) C-003
          U2140 CAN bus no communication with CIM (Steering Column module) C-003
          U2140 CAN bus, no communication with UEC (engine room electronics central module) C-003
          U2141 CAN bus, no communication with REC (Rear electronics central module) C-003
          U2143 CAN bus, no communication with SAS (steering wheel angle sensor) C-003
          U2144 CAN bus, no communication with ACC (adaptive cruise control) C-003
          U2145 CAN bus, no communication with PAS (Park Pilot) C-003
          U2146 CAN bus, no communication with SLM (driving stage / Fahrprogrammwنhlhebel) C-003
          U2147 CAN bus, no communication with AHS (Zuheizer) C-003
          U2149 CAN bus, no communication with TPMS (tire pressure monitoring system) C-003
          U2173 CAN bus, no communication with PEPS (Open & Start) C-003
          U2174 CAN bus, no communication with AHS (Zuheizer) C-003
          U2174 CAN bus, no communication with EHS (heating) C-003
          U2181 CAN bus, no communication with elektrohydraulischem hardtop C-003
          U2201 CAN bus, no communication with RQ (Entertainment Head Unit) C-003
          U2202 CAN bus, no communication with CDC (CD changer) C-003
          U2206 CAN bus, no communication with DIS (advertisement) C-003
          U2207 CAN bus, no communication with UHP (Univ. handsfree) C-003
          U2208 CAN bus, no communication with ECC (Electronic Climate) C-003
          U2213 CAN bus, no communication with DAB (Digital Audio Broadcast) C-003
          U2215 control device to replace C-002
            nice one mate, how does it actually show the code? will it read it in the small screen where the milage is?
              aparently not...see below....
                Doesn't this only work on the astra?
                Rabbid Tuned - WG Motorworks
                www.wgmotorworks.co.uk
                  fair question...i dunno
                    Yes only works on the astra.
                    You will need a ECM code reader to extract the code on the corsa using the diag port in the centre console to the left of the cig lighter.
                    Not all of the above codes refer to the corsa eg the one for The egr valve.
                    CORSA VXR
                      i did just try this and the light that looks like the engine flashes on the dash in a sequence. kinda like a morse code thing. wuld this relate to anything?
                        sorry bud...i donno,
                        i can do astras but not corsas apparently...
                          i thought so.
                            Sure that codes on the Corsa can only be read by a fault reader / techII
                              but also bluefin fault reader isnt working well (NEVER WAS WORKING) in this case
