Hi Buddy, ..the Corsa I believe has projector lensed AFL headlights and therefore you don't need the 'anti glare' HIDs, just the standard ones.
No probs, ..I have an Astra, but it was fitted with standard reflector headlights, so when I swapped them over to BiXenons, I put standard D2S HIDs in and they look exactly the same as factory fitted ones. So, I believe you'll just need the H7 HID's and not the H7R's. These only need to be fitted in reflector lenses. Paula x
I best get hold of car mod shop because i bought the H7R's and the only difference i noticed was the colour, they werent any brighter and to be honest arent bright enough. Will it make a difference between H7 and H7R?
Not really fella, ..you probably wouldn't notice any difference fitting the H7R's into your lights, ..I wouldn't bother swapping them over. It's only a little line of black paint that makes them H7R's anyway, ..just use them, they'll be fine. At least you know for sure you're not dazzling any drivers!
