Silly Tyre Repair Kit
  • Silly Tyre Repair Kit
    How useless is the tyre repair kit in the Corsa?! Had a flat tyre earlier which was caused by a screw (it was no longer there but the damage was just a single hole bang in the centre of the tyre). I would have imagined this sort of damage would be the bread and butter of the repair kit but Oh No! I could hear the air still escaping and when I did make it to Kwik Fit it had all come out and covered my arch! What rubbish.
    Then Kwik Fit didn't have the tyre in stock so my car has been left with them for the night
    Used to be a Black Corsa VXR
    Now a VW Scirocco
    it is pretty shonky stuff, never trusted it!
    and im still to fnd a garage that will stock a 225/35 tyre!
      Oh, forgot to ask. For those that have used this before, do you just get a new can of foam from Vauxhall? What sort of cost am I looking at? Might not even bother, may use the space more constructively to hold some digestive biscuits or something.
      Now a VW Scirocco
        Haha yer same here. The only time they did have one in stock was when they had ordered an extra 2 in for me as they knew I'd be back fairly soon. But by the time I had come back and needed 2 tyres they had sent 1 to another location!
        Now a VW Scirocco
          Just buy some tyre-weld.
          If the hole is in the middle of the tyre, it should be repairable (if under 6mm, which if its bigger, you can't expect the tyre repair can to plug anyway!)
          Mike Hughes
            The tyre actually needs replacing anyway as the tread is quite low. Plus the use of the repair kit apparently makes the tyre unrepairable.
            Now a VW Scirocco
              get one of these in the astra too, was useless, lighter than a spare though
                Depends if it "sets" or not, doesn't sound like yours did.
                Mike Hughes
                  Ah I see, no it was a nice white liquid
                  Now a VW Scirocco
                    your supposed to put it in drive for 5mins then recheck, not sure if it would seal though as there was a hole in it. you can buy them from vx, think theyre about 25quid
