Overboost?
  • Overboost?
    Can anyone explain what this is. Asked a guy in Thurlow nunn today about it but he didnt know (wasnt a salesman was manager lol)
    thanks
    It basically activates automatically is 3rd, 4th, 5th and 6th gear when the throttle has been held down for more than 5 seconds and increases the peak boost from about 15psi to about 17. So just gives you that extra bit of wind behind you
      ah right ok. thats pretty cool. thanks mate
        every so oftain mine peaks at 1.4bar (about 20psi) do you think i should go get it checked out?
        Mods: Carbon wrap bonnet, carbon wrap roof, carbon diffuser, clifford, boost gauge, Wind deflectors, tints, TD 1.2s with R888 rubber ready for the summer, RARB and braces!
        Future mods: springs....
          Bang!
            Is it running standard map? Do you have a down pipe, If so you may need to adjust the actuator slightly.
              Originally posted by stevevxr1 View Post
              Bang!
              FFS get a life mate, I think everyone has had enough of you!
                agreed!!!!!!!!
                Corsa VXR now sold
                  Mine peakes about at 1.2 bar .. too low?
                    1.4bar peak isnt to bad, nothing to major. what mods do you have?
                      boost can never be to low aslong as you still make the power i would love to have the same power running 1.2 or even 1.0 bar!
                        i am totally standard. its not that oftain that i see it peak that high usually its about 1.1 to 1.2 bar. suppose it could be the weather?
                          The boost gauge fitted, should be read as indication purposes only, they are all innacurate by a far margin of error, and im not talking a few percent either
                            I relise that mate, but when it always shows 1.2bar then a few times is shows 1.4bar then it must be boosting more?
                              I believe that could be due to the software overboost.
