Front Pads
  • Front Pads
    With ones should I get
    I have standard front brakes, coming up to my 40'000 mile service and will need new pads, but would rather fit them my self as I will be cheaper
    Do I go for standard Corsa VXR pads
    or The green stuff
    or any other suggestions,
    money is an issue so I can't change for bigger brakes
    i can supply genuine vauxhall pads at £40 delivered if you wanted. RRP £50.71.
      good price.
      Rabbid Tuned - WG Motorworks
      www.wgmotorworks.co.uk
        nothing wrong with standard parts if you dont mind the squeek ( i dont)
        and 40 noops seems pretty good mate
          lot ppl are talking here that yellow staff are cool, if that help.
            sounds like a good deal i'd stick with £40 standard pads, i like them as they are and maybe they are a better compound now as mine don't squeak unless reversing
              I'm running redstuff pads and they are spot on imo
                just bought some Redstuff
                see how they perform
                  is that what the famous squeek is the pads ? so in theory if changed to
                  say ebc it should eliminate it ?
                    vauxhall changed my pads yesterday (under warrenty) and they are squeeking worse now then they did before they were changed. Is this normal?
                      WTF surely that aint right
                      which is why im wondering if aftermarket gets rid of the problem totally
                        I know, perhaps they didnt put any or enough copper grease on them?
                        I have only covered 7 miles since they have swapped them, but at low, soft breaking they are squeeling like a lil piggy.
                        Quite embarrasing when im driving into work's car park
                          Mine were really bad when I first got the car.. Replaced the disks with some EBC grooved ones and replaced with braided lines and just got a new set of OEM pads from VX.. I just put a load of copper grease behind the pads/piston and have never had a single squeak since even in reverse
                            Is it not just the brake "wearing in"?
                            Originally posted by Bobbyp90
                            South East Regional Organiser
                            PSN: TomFL12
                              Unfortunately not! Most if not all corsa standard brakes do it! Some worse than others! Mine only do it when reversing down a hill and I gently apply the brakes!
