question about intercooler and header tank
  • question about intercooler and header tank
    if you fit the forge intercooler with the metal piping does this mean you cant fit a dump valve?
    http://www.forgemotorsport.co.uk/con...duct=FMINTCVXR
    bottom picture. the metal hose is the same one the dump valve would normally fit to?
    any what do people think of this/has anyone fitted one. Any pictures -
    http://www.forgemotorsport.co.uk/con...oduct=FMHTCVXR
    you can maybe ask them to make you one with the dump valve housing like my one
    My Progress Thread : http://www.vxronline.co.uk/forum/showthread.php?t=55899
      looks sweet. any problems with air meter? is it a twin piston dv?
        dc44, do you experience any problems with the dv?
        Any error codes? boost leak? loss in power etc?
        Did you have to block off your internal DV?
          no problems with the air meter, yes its a twin piston
          http://www.forgemotorsport.co.uk/con...oduct=FMDVWO34
          i did when i first fitted it, it went into limp mode. i sorted the problem out by putting a stronger spring in it and that sorted out the problem.
          but when i fitted the forge diverter valve it went back into limp mode again so took it off and it picked up a lot better without the DV. i would recommend a forge diverter valve.
          i have put the DV back ever since i have had my car remapped, seems to be fine no problems. not sure if i am going to keep it or take it off yet havent made up my mind
          and no my internal DV has not been blocked.
            ok, cool...
            So you running 2 d/v without problems?
              ok, cool...
              yes
                Thanks buddy...
                I can't seem to get it right here... maybe it's the [email protected] fuel and the altitude?
                  Tha altitude?? We live by the sea, just like them...
                    mmm....
                    But they are living in higher grounds.... hence, colder weather...
