Just quick question, does anyone know if this will work on the corsa? Or is it for the astra only?
thanks
Astra Edition #105
As long as you buy a twin piston collins it will be fine,both bayleys dv 26 and 36 work fine on both astra and corsas so collins will be no different mate
ppl say it does, i bought one the twin piston one and you couldn't hear it, so they sent me the softer spring and it kept going into limp mod. but i do know that some are running them.
I had one fitted for a while, Definatly the loudest DV of them all but It put my car into limp mode after a while.. LukeVXR had exactly the same problem with his too..
