Squeaky breaks when reversing
  • Squeaky breaks when reversing
    I don't know if it's just me but I've noticed my breaks squeak when breaking in reverse does anyone else have the same problem and what should be done?
    Snapchat me joshreinbach2
    I get a bit of noise from the brakes every so often. Probably just a slightly more aggressive pad compound that are fitted the VXR. Nothing to worry about unless its constantly screeching.
      Yep mine does this too now and again, don't think it's anything to worry about!
        My rear brakes also seize every morning after being parked up overnight.
          Think I'm going to take it to Vauxhall in the morning to get it looked at will let you guys know how it goes.
            That happens to me too, intermittent though
              Braking when in reverse can cause squeal but it is nothing to worry about, and doesn't happen every time. It is quite normal. Most braking is done in a forward direction so the particles/fibres that make up the brake pads are worn down in a forward direction. Braking in reverse means the disc is rubbing 'against the grain' of the brake pad particles/fibres, and you never put as much pressure on the brakes in reverse so the pads have a chance to vibrate (squeal).
