I have discovered that when entering any address on the other side of the Channel, you are taken via the ferry at Dover. The Nav wont use the Eurotunnel at all.
Ticking the relevant boxes in the config settings to either avoid ferries or avoid tunnels makes no difference to the route.
I wonder if there is an update to the hardware/software available?
It used to work ok on the CD70 set up on the Astra just fine.
Also the max 2.00 GB capicity on the car hardware is insufficient to load GB plus France plus Switzerland plus Italy, meaning you have to remove one of the previous to load the last. Not very convienent when this not only takes a long time but also means having to take the CD with you, and then to reload back again.
At least on the Astra CD70, with seperate discs it was simple and quick, even if you did have to take the discs with you.
Looks like some work required from Vauxhall on this one.
