Clutch issues?
  • Clutch issues?
    does anyone here know if VX have been having issues with clutches in the insignia range?
    the car has done 3000 miles and the clutch is badley slipping in second gear under heavy acceleration.
    Tech2 Diagnostics
    I have the SRI 2.0T, has been spot on before and after my remap. Not heard of any other reports. Get it back to the dealer mate.
      any other guys had issues?
      Tech2 Diagnostics
        I've done just under 1000 miles in mine and as yet had no problems.
          I had one for ten months and never had a single problem with it...I miss the insignia and will probably get another one early next year. You can't beat the ride comfort and that massive boot In a vxr corsa at the moment so it's a huge difference
            Nope there are no reported issues on the clutch. I'd take it straight to the dealer for investgation.
            Stu
              my clutch has started slipping under load, done 7000 miles.....
                There have been some rumours of clutches going after a remap due to too much boost at low revs
                Unless I guess someone can come on and say its them it will stay rumour, mine has slipped a bit once after I rode it a bit in traffic the other day but I think any car would if you got the clutch hot enough
                The adventure is over, Blue Beast, gone
                  just to let you guys know. is it normal to have black soot/oil on the clutch face? i think it was oil as it made your fingers slippy
                  Tech2 Diagnostics
                    Thats not normal the clutch face should be dry. u might get some clutch dust. Is this on a Insignia VXR? or the Astra in your sig?
                      na an insignia. the face did feel oily
                      Tech2 Diagnostics
                        Vauxhall Insignia 2009 Only 3886 miles
                        I have been driving for 47 years and driven most types of cars. I have always treated my vehicles with respect. Broke down on the road and the RAC guy informed me that the clutch had burnt out. Never have I burnt out a clutch. At 3886 miles this seems absurd. Towed to the local Vauxhall Dealership who stated that, unless a mechanical fault can be proven, the repair will be my responsibility. Is this reasonable? Has anyone else had a similar problem? Is it possible that the clutch assembly was frozen during the recent cold spell? Any advice would be really appreciated.
                          im hoping this is just the normal procedure with rules on warrenty and modifying cars tightens up. In your case it appears you have alot of experience on your side and i hope that common sense prevails
                            Vauxhall Network Q covers the clutch
                              replied to your PM
                              Tech2 Diagnostics
