Front drilled discs
  • Front drilled discs
    Has anyone had a close look at the drilled holes in the front discs ?
    Just had one of my wheels off to check the pad material thickness & noted that all the holes were blocked with brake dust/friction material.
    So took the time to clear all the holes out with a 3.5mm drill. Will be doing the other side tomorrow.
    Doubt I'll notice the difference, but at least they aren't clogged up now.
    sigpicBLACK COUNTRY BORN AND BRED
    Each time i clean the car i jet wash the crap out of the holes.
      the holes are there to disperse heat so keeping them clean will help them do there job. im the same as you baz jet wash the hell outa them. lol
      INSIGNIA VXR
        I give my wheels etc a blast of finesse iron treatment every now and again... Scary what comes off... Also I too give the discs a good blast!!
        RUN YOUR FINGERS OVER MY CAR ....... AND I'LL RUN MY CAR OVER YOUR FINGERS!
