Hub nut size rear right side
  • Hub nut size rear right side
    Hi guys checked my hub nuts 3 are 32mm but one is 36mm rear right.phoned vauxhall they said m24 nut
    M24 means thread size is 24mm with 32mm size for the socket
    Sound likes someone has used a nut with 24mm thread and 36mm spanner size
    Its uncommon but it does happen someone was probably just in need and it's what they had laying around the garage
      Ok cheers mate thanks for clearing that up would it effect anything should i get it changed or leave it cheers
        Not really you could just leave but it wouldn't hurt to change it
        Just ring Vauxhall they will supply the right one
