Vibration issue help please
  • Vibration issue help please
    Hi guys latly been having issues with vibration whole car shakes rather than just steering wheel
    basically when i drive normal you cant tell much but when i floor it then you can feel a vibration through the whole car also it does it mainly in 2nd 3rd gear also as the revs get higher it easies off id say most apparent between 2k and 3.5k rpm thinking of changing propshaft also needs timing chain doing got p0008 code which is next on the list. cheers all help appreciated
    reads like you have found the problem pal
      It wont be the propshaft. Possibly MAP sensor. They cause those symptoms when knackered.
        Problem was propshaft sorted now cheers
