Help knocking sound intermittent at idle video attached
  • Help knocking sound intermittent at idle video attached
    Hi guys at idle my car makes a knock kind of sound does anyone know what this could be it seems to be coming from the intake.manifold in the center maybe cams lifter or bad plugs or something else all help appreciated thanks https://youtu.be/ccv6n9yndXs
    can just about make that out i would start with an oil change I don't think its a plug as that would cause it to run rough, and does this happen when cold or warm?
      https://youtu.be/IgFjg8H88ik heres another video cheees for the reply it does not run ruff sounds like a misfire when the grind noise happens oil was changed and filter by the garage i might do it again and get the filter and oil from.dealer cheeers
        personally I'd take the pulley belt off and try running it again , that will conclude roughly wether its engine related or not pal but obvs not for too long
