Insignia VXR bhp/ton
  • Insignia VXR bhp/ton
    Anyone know what this for the Insignia and Astra VXR? I cant find the weights anywhere on Vauxhall's website.
    Insignia weight: http://www.carsuk.net/vauxhall-insig...press-release/
    it really heavy !
      That means that the Astra VXR has a higher bhp/ton than the Insignia VXR!
        the insignia is a bit of a porker
        almost as much as the fullsize VXR8 !
          This is whats putting me off getting one. It wont feel faster than my Astra except for off the line.
            Speak to courtenays
            their 400bhp turbo upgrade will sort that
              Has a corsa vxr cooler too lol, not sure if its a day too day runner tho, im not too clued up, i know it was for the fastest opel speed around a track in germany, well this is the info i was given
                Originally posted by MrLOL View Post
                Speak to courtenays
                lol, exactly
                  and every corner you encounter.
                  Stu
                    Suppose so. They do look a lot nicer in te flesh I am just waiting to see a white one as I've only seen a arden in the flesh.
                      I saw a white one the other day, i was following behind it and its lovely, and they sound amazing
                        I'll see if I can record the start up noise. Now its gotten colder it really is rather noisy )
                        Also the instant mpg on starting on the fast idle sits at 2.9gallons per hour....
                        Stu
                          I noticed that the insignia does sound a little more throaty as standard
                          mine took a milltek exhaust to liberate some extra sound out of it !
                            yes it does have a nice grunt from it.my mother in law is complaining its too noisy lol
                              Stu
                              That's the thing though, VXR owners expect a bit more than from the Flagship than just better in the Corners and off the line, the insignia should be better in all areas than it's little brothers as it is with the other VXR's, I've driven the Insignia and as lovely a drive as it is, per formance wise there is only a small difference in straight line speed between it and the Vectra 280.
                              I want to buy the Insignia possibly next year, what I would like to know is are you planning to upgrade the power on the insignia the same way you did the Vectra as this would certainly sway me over as I feel that the output of the insignia at the moment is lacking, especailly when you factor in the Cars weight and then transmission loss from the 4wd system.
                              My honest thoughts are that the Insignia should have came out with 340ish bhp that way the difference between smaller VXR's would be more noticeable.
