remove / install pre cat delete pipe
  • remove / install pre cat delete pipe
    before i begin , you really need a 2 post ramp for this but with a decent trolley jack and axle stands its easy enough on your driveway
    you will need
    socket set 3/8 or 1/2 inch
    trolley jack
    axle stands ( optional )
    13mm & 15mm spanners
    2 13mm nuts bolts and washers for new pipe
    "how to"
    firstly raise the car , needs to be quite high and in the middle can be at either side , be carefull not to damage sills or skirts , use axle stands for extra support if needs be
    get under the car and locate the front pipe , its obvious , familiarise yourself with what is where! it has 3 tri bolt fixing at the front ,a hanger and 2 bolts at the back
    now using your socket set , setup the long extension , ratchet and 13mm socket , undo 3 front nuts and gently pull it till it dangles ,
    now undo the 2 rear 13mm on the centre section and part til the front pipe is free to be moved around
    now take a 15mm spanner and above the hanger is a nut ( spanner will be aginst the heat shield but there is room ) , its fiddly but undo this nut and then be ready to catch the pipe as it reaches the end of the thread , once you have the pipe off all you need to do is part the hanger rubber and the zorst , undo the 13mm and squeeze it off , use PTFE spray to make it easier as it is kinda tight !
    thats removal ,
    ive only dealt with the bashtuck delete pipe which has no nut on the zorst hanger , so squeez zorst back on to hanger then your ready to install ,
    make sure both front and rear metal gaskets are in place , use zorst paste if needs be ( but you shouldnt need it )
    firstly put the nut in the jaws of the 15mm spanner ( the nut will still be above the bracket) the spanner will hold it centre while you start it off , gently offer up the hanger then turn the spanner , it should start easily but persisit if it doesnt , once it is then tighten it up fully usuing the open end of the spanner
    pipe should then dangle
    now reattach the front 3 bolts with gasket , nice and tight
    then the rear 2 with gasket , you will need a 13mm nut and bolt for each side so use socket set and spanner to tighten , and thats it
    lower the car and check for leaks once the car is running
    any Q's about this process PM me im HTH
    cheers
    This sounds very helpful mate thanks bud!!
      This sounds like the main cat pipe not pre cat.
      good write up tho.
      Saab Turbo X 2.8V6T XWD - JZW stage 1 REV 1 - 321bhp 437 ft-lbs / 592NM
        Which is the best one to buy?
          The best option is to change the pre-cat pipe ( turbo - secondary cat) for a 3" de-cat. Then change the secondary cat for a 3" pipe with a 3" sports cat.
