Gen 4 haldex service "how too"
  • Gen 4 haldex service "how too"
    I carried out this service this afternoon inc rear diff
    you will need : new filter , seal and oil , 1/4 drive socket set ,3/8 ratchet and 6" extension bar , 1/2 socket set , decent set of alun keys , drain tub , a way of refilling ( I used a hand primer ) , some rags
    1.raise the car up at the back ( I used axle stands , be sure not to use the subframe to support the car )
    2. remove rear half of the zorst
    3. using an 18mm socket & drive ( buzby gun if you have one ) , drop the x4 sub frame bolts & the x2 diff bolts
    ( this will give you ample room to access the 10 4mm hex bolts that hold the filter in place ) at this point undo the larger hex refill plug but don't remove it just yet
    4. put drain tub under filter housing cover , remove 10 bolts using Alun key or 1/4 with hex attachment if you have them , allow to drain thoroughly & remove the cover , there is a breather pipe at the top left corner , leave it attached and dry the cover in situ
    5. clean any metal swarf that's collected in the bottom of the housing with a rag & swap the filter for a new one & also swap the seal for a new one
    6. once dry replace cover and tighten x10 bolts evenly ( they don't need to be mega tight 5lb or there abouts is the official torque setting )
    7 . you are now ready to refill but at this point I tightened up the x6 18mm sub.f bolts back up as access to the filler plug is easy with the sub.f in its correct position , you may need a separate jack for this operation ?
    7.5 refit the exhaust
    8. the beauty of this GM version of the Gen4 is there is only a refill hole so when you pump in the fresh oil , its impossible to over fill it , so fill it till it spills over a little and then replace the plug , at this point you have a choice , I chose to drop the car down and run it up the road , cycling thru sport and VXR modes a few times , then once back I checked the level , it need another 50ml of fluid just to top the level off , OR raise the front of the car aswell and do the same thing in situ
    9. REAR DIFF , using a 3/8 drive with 6" extension and a drain tub , undo the diff drain plug & the refill plug , clean thoroughly as they are magnetic and will be covered in metal swarf , once fully drained , replace drain plug and fill till it overflows a little then replace filler plug , again cycle the diff using sport and VXR buttons , the top up if needed
    10. make a note of the mileage so you can keep the service interval correct
    There , All done !
    I hope some of you will find this " how too" useful , it really isn't as difficult as it appears with a minimal amount of kit needed to carry it out
    cheers
    Bembo
    Good job, there is a decent video from a Saab owner https://www.youtube.com/watch?v=XsighGggo8M
      yes pal , ive watched it but the saab has a different exhaust from what I can tell , on those you don't need to move it to carry out the work
        That's good to know, hopefully just about to have mine serviced at my cousin's garage
          Have you get link to the oils that are needed as when I seen on line they use 3 different one
