help help my merv vxr running ****
  • help help my merv vxr running ****
    hi guys could do wiv sum help wiv my merv vxr 06 34k it started playin up when i change from 1 st to 2nd it drops power as if the throtle is snapin shut when i lift off its becoming more and more frequent . done the brake and acc pedel test and then held down the trip reset button 4 5 secs the numbers 1281 came up .does ne body no whot this would mean thanx neil
    get tech 2 on it mate better safe than sorry where u from
      whats tech 2 in from burm 8 miles out of centre
        go to vauxhall they will put they're tech 2 (diagnostic comper) on and tell u what it needs
          Any other symptons? Rev hunting in neutral, rough idle?
            no all clear no hunting or bad idle
              Definately get it in to be checked, could be a sensor issue. Unfortunately I don't have the meriva DTC list, but if they get it onto tech2 then it will give the description for the code stored and hopefully it's something as simple as a boost solenoid
              Keep us posted and sorry can't help more
                ESP lamp on as this happens?
                  Good point, although I would hope he knows what the TC/ESP can feel like and do
                  Just a shame you don't have a button in the Meriva to turn it off, like you can in the rest of the range. Very annoying when I drove one round track
