Meriva ESP / TC
  • Meriva ESP / TC
    Hi,
    Just read that ESP/TC can't be switched off in meriva. Is this true or is there some kind of trick to turn it off?
    I thought of this but, didn't see a way of doing it. Probably same as old Zafira GSI.
      There is a fuse that turns off the ESP, can't remember the fuse number but you will also lose ABS / Airbags so not recommended for road use. I had to remove it once because the car refused to work in dyno if the ESP was on (rear wheel sensors not getting info so the car doesn't pull). Result was 178bhp 280nm. That was with 95 RON, I'm going to dyno it later with 98 RON but acceleration timings would indicate 10-15 bhp for the better.. There is already a dyno result with 190bhp from a similar car.
      btw, with overboost = 310nm!
        Contents deleted, as is user
          warning
          do not open the above attachment please
          sorted!
            just delete the post
              Insufficient access...
