HOW TO use lead me to the car lights
  • HOW TO use lead me to the car lights
    Some people have experienced that the instructions in the user manual only results in a beep, so here are the instructions that does the trick:
    1) Unlock doors with the remote
    2) Open drivers door and keep it open.
    3) Put the key in ignition and turn to position "II"
    3) Press and hold the light switch until both green indicator lights by instruments light up
    4) Release light switch
    5) Done
    To test it
    1) Lock car
    2) Hit unlock button on remote twice, first time unlocks and second time turns on the "lead-me-to-the-car" lights.
    Thanks to jeremy for this finding
    does this work on the corsa vxr
      Or astra
        Give it a go to find out is what I say
          What are these exactly
            Basically when set you can unlock the car, and if it's dark and you can't see particularly well press the unlock button again and it'll turn on the cars lights to aid you getting to it hence - Lead Me To The Car Lights
              Thanks Alex have to try this :wink:
                Slight correction if you set this function on the Meriva, it lights as soon as you unlock the car.
                  Even in daylight
                    Yep, thats the disadvantage, but good in a car park
                      it does go off after 30sec or when you turn the engine on i like it
                      FABIA vRS WITH PD160 INTAKE, PIPERCROSS FILTER, STRUT BRACE, EIBACH PRO SPRINGS, 312MM AUDI TT BRAKES,BOOST GAUGE,FMIC, WATER SPRAYER, RARB, WIDE MOUTH BUMPER, 17" OCTAVIA vRS SPIDERS PAINTED GTR GRAY WITH PRADA SPEC 2's AND CELTIC TUNNED
                      182.1BHP-300FT-LB @ 26 psi 1/4 MILE 14.966 SEC
                      "NO SMOKE NO POKE" R.I.P MIGHTY MERV
                        just given this a try on the astra and couldnt get it to work, anyone confirm this?
                          i showed darrenvxr how i did it on mine he tried it as well but it wouldnt work
                            Done mine this morning makes the AFL look good aswell when it comes on :wink:
                              does work on the corsa vxr but need to get onto a menu
                              read manual
