Hello to you all.
This is my first post and I hope it might help someone else here.
My 2009 VXR8's ABS warning light came on last week. Scanned ABS ecu for codes. N/S/R wheel speed sensor fault. Ordered and fitted new sensor.Same fault..... Followed the wiring from the N/S sensor across the top of the diff to where the O/S wiring joins it. There is a nasty little multi plug connector stuck up the side of the fuel tank. The wires are twisted together in the loom,and are under tension when they get clipped up under the car. One of the wires had snapped at the connector. Cut connector block off, soldered all the wires together,covered with heat shrink... code gone....light off!!
Bit long winded, but hopefully of some use!!
ssarg
ssarg
