C0040-00 code
  • C0040-00 code
    Hi people I got a VXR8 and have abs and esp light on
    plugged her in got brake pedal switch a (code c0040-00)
    fitted a genuine one and still the same
    any help very much appropriated
    Evoke grey,2008,Vxr8,manual,LS2,Walkinshaw wild cam,uprated lifters & springs,SP230 supercharger,uprated leads,remap,uprated fuel pump,short shift gear lever,full exhaust with cats and headers,uprated clutch,Pedders and hids
    POWER CHANGES EVERYTHING
    What’s the state of your battery as these cars are renowned for throwing up all sorts of strange electrical problems if the battery is weak
      hi thanks for response it’s new battery but the fault won’t clear with scanner 🤷🏻‍♂️
        Does clear on scanner but car wont
        just says
        c0040-00
          Have you tried disconnecting the battery for 30 mins?
            I think c0040 is front right speed sensor, is that what you mean?
              Yeah I read it was that but it comes with brake pedal
              ill do some more live checks
              thanks for your help mate
              will keep you posted 👍
                No problem good luck😎
