Right, this may seem very vague, but that's to save any sensitive info being spilled by accident lol,
Right, in basic terms I think there a waste of money, you get absolutely no gains power wise from this mod,
Yes you get a nice sound, and on full chat its awesome,
It will smooth out the power from say 2k revs upwards, but not really worth the money, unless........
Unless your chasing big power, it will be beneficial, in the long run, with some choice mods that I can't divulge, but this is still a few months away from hitting the shelves,
If your chasing big power I'd hold off a couple months if not, don't waste the cash on this, just buy a cooler and water rad that's my advice mate
As for your exhaust system question , there are no gains taking out the centre section, just a nice noise
The standard exhaust was used on the sledgehammer project and that seen 370 bhp at 1 point so it will be fine, just be careful as they may insist you buy a milly, before they give you the map,
hi have had a custome exhaust on and no center box and a decat pipe made for it.have got thourney stage 2 map.my question is have i done the write thing.i.e sound,s good.
But not shore if it gives more power thow and seems to ues more full.should i put cat back on???????
Any advice would be good. Cheers in advance
sigpicCUSTOME EXHAUST,TOUCH SCREEN,SATNAV,REVERSE CAM DVD,TV,BLUETOOTH
ITG,SMD,STAGE 2 MAP,CUSTOME GRILL,TINT,S,H and R Springs,GEO,DE BADGE,PRO RACE 1.2 ALLOYS,VXR PEDALS.BOOST GAUGE,BLUE FOOT WELL LIGHTS. BONNET RAISE,BONNET VENTS,OMP Seats ,Caged,Weight Reduction,Hydro Dip,Inlarged Intake,Mod Air Box,Up Rated Disc,s and Pads.
The decat front pipe did cause an emissions light on mine after about 70 miles but after a couple of tweaks to the map its gone now for the last 1000 miles.
mine to have you been to the car test(mod) with this set up..?
Lambda 2 has to be removed from the map. It may not pop the eml light as its only a check of the first wide band lambda (Pre Pre-cat), but best to write it out of the program.
