seating
  • seating
    Right, I feel I want some new bucket seats for my car, I also want harnesses fitted,
    I have no clue about these kind of setup and wondered if anyone else does? I have asked a few companies if they do runners etc for a vec but to no avail,
    Also where could I fit harnesses as there are no options that I know about for harness bars etc, I don't want to bolt the top part of the harness to the floor
    Blimey, not a clue...
      Well I see this one dying a death pmsl, il just get suspension
        with reference fitting harnesses the best way is to use the original seat belt connection points and this is the easiest way with out drilling through the car. with the seats you way mell have to make an adaptor piece to make the seat fit onto the runners you already have fitted in your car.
        jonesy
          I love the corsa seats, think they would suit the car as well....if only they were electric!
            agree with you there. do think they would look good in front of a vec. would like to think it would be much simpler to fit then after market seats.
            jonesy
              I love them too, hmmm decisions decisions, wonder if they would fit straight in
                only one way to find out. see if someone you know has a corsa with them and see if they would let you try to see if they would fit.
                jonesy
                  Of corsa they wood! ;>
                    They may have slightly different fittings you never know till you try.
                    jonesy
                      Oh god...
                      Its 'would'... not 'wood'
                        Harnesses should be an easy job Stewart.As said before,utilise the side fixings by the seat,then use the rear mounting bracket holes for the rear clamping brackets.SHIMPLES.If you use the CORSA seats,the straps will fit straight through the back of the seat.
                          Originally posted by spoons View Post
                          Oh god...
                          I no...
                            I no...
                            arrrrgh
