Suspension? (IDS plus and IDS2 plus)?
  • Suspension? (IDS plus and IDS2 plus)?
    I'm guessing the 255 models have Ids and the later 280 has ids2 yea?
    Or do they both have the same system but the 280 got an update of some kind?
    T598 Dave
    Are you VXR enough?
    It aint about how hard you hit............ its about how hard you can get hit and keep moving forward!
    both ids2 as far as I know but there are couple of small changes on the 280 but vx now only supply one for both 255and280 how come? you looking at buying Stews like
    #1
      I thought maybe the electronics were different? I know they have different springs but thought the dampers were the same.
      I want to fit eibach springs in the future, was just curious of the difference between the 255 and 280
        for getting some eibachs the only thing will be if its hatch or estate for axle weight regardless of variant
        #1
          cheers mate.
          im told the eibachs match up with the dampers real well and improve handling but will the shorter springs wear the dampers out much quicker?
            can't see the shorter springs making any noticeable differance in life its not like your planning on dropping 100mm and slamming the car to the ground
            #1
              ok then thats good news yea i guess its only about 10mm
                I think most of it will be in the luck of the draw as it is. If you think mines just had a shock changed on standard springs but can't think of anyone with springs fitted who's had to do theirs
                #1
