VXRacing Vectra 6-Pot 362mm Brake Kit
Before the rumour get out and the car gets spotted we thought we would give you a preview of what we
are currently working on in-conjunction with VXRPerformance Centre and AP Racing.
Note the pictures shown are of the first pre-production kit so there will be some slight modifications
to the final product. The final kit will be a big brother of the Astra VXRacing kit with the VXRacing
logo and colours available in Blue or Red.
Continuing the BTCC link to the VXR road cars the Vectra VXRacing 6-pot kit uses the same body
castings as the current APRacing TOCA Touring Brake Kits.
Below is some interesting comparisons to the standard VXR.
Weight:
Component weight comparisons.
Caliper & pads, VXRacing = 5.10Kg v's VXR Standard = 7.95Kg
Disc& bell, VXRacing = 8.75Kg v's VXR Standard = 12.10Kg
Corner weight, VXRacing = 13.85Kg v's VXR Standard = 20.50Kg
Yes, that is a 6.65Kg saving per corner
Pad Area:
VXR Standard Pad area= 84mm x 64mm
VXRacing Pad = 152mm x 54mm
Yes, that is 52% increase in Pad area
Linked with an obvious Pressure improvement from the 6-pot Caliper over the original 4-pots.
VXRacing Vectra 6-Pot Brake Kit consists of:-
Caliper: - VXRacing Branded 6-pot road type, integral piston wiper seals, pad anti
rattle clip, protective paint coating. Piston area 50.1Cm².
Pad size = 152mm long x 54mm deep, thickness 17mm, area = 76.3Cm².
Disc: - ط362x32m, with 48 curved cooling vanes & 12 curved face grooves,
handing the disc left / right.
Alloy disc bells supplied assembled to discs, caliper mount brackets,
Goodridge braided hose, Hose armouring, all mounting bolts, washers, 1 Ltr
Dot 5.1 High temp brake fluid.
Prices are to be confirmed shortly
Please note VXRacing AP Vectra Brake kits will be available through selected tuners and Vauxhall
retailers in the future.
To be the first to have the VXRacing AP upgrades please contact VXR Performance Centre on 08702424334
or email [email protected].
Weight:
Pad Area:
