As you all probably know the tail pipes on the Vecci are clamped on. So off I went to find a goos quality different pipe. NO managed to find what I want yet, but worth considering that if you want to change the look every so often then I'll keep you up to date in what I find.
I wouldl ike to see 2 x 2 rounds, nearly had them but they are 3mm too small. Off I go again. If anyone finds some the bore is 61mm and total cross section is 137mm whilst the bottom of the exhaust pipe to the valence must not exceed 85mm. All change!!
