Yes your right, it did definately say it was £800 and it has changed. I always thought £800 was a very reasonable price. £1,250 is still quite good value however.
Good Value!!
Don't think so.... a 50% increase in price.
Petrol took almost 20 years to do that!
Personnally I'll stick with the DAB anyday...as I know my way around already ;>
The original reason for the £800 was the VXR was fitted with a colour screen already so did not require the £450 screen. SO I guess they may well have changed the spec or its a mis-print.
Good Value in comparison with some of the factory fit systems from other manufacturers. For example the last time I looked the BMW one is nearly £2k
I can recommend the DAB unit. We came back from Devon today and Gabriel wanted to listen to the Manchester Derby. Radio 5 Live was for once audible.
That's intersting, our VXR doesn't have a colour screen.
Yes it does. Actually that question has prompted me to raise a point. I have noticed that when I picked the car up yesterday I could press the Auto button to switch it on (little orange light came on). Now I can't actually turn it off.
Is that correct?
Is it climate or auto. As the the only auto button I have is the windscreen auto, but my fan speed dial has a auto position to regulate the cabin temperature. This method is not as good as climate. If it true auto then the button should turn off, climate may need something else operated, such as turn the fan to manual. Let me know
Fair enough, was just that I almost ordered one...but opted for something else instead.
Just a bit shocked to see the increase.
I did notice that the vxr in my dealer has a sort of plastic surround at the edge of the screen so at a guess that is very similar to my MID in our GSi...its just the basic stuff.
So with the ECC can I expect the larger screen also?
I think but don't hold me too it, you will still only get the smaller screen. I know in the Astras that unless you order Nav you do not get the colour screen. However, also on the Astra I know you can change the screen to colour, but withth associated cost of about £600. I think the problem is they change everything from day to day. I didn't expect to xenon's but due to a supply issue they decided to fit xenon's
Sorry what I meant to say , the car was never due to have xenon, just optical dipp beam, but VXl decided to change. Interestingly they didn't intend om fitting cruise!!!, until I asked why not and they then decided too. Crazy
