Any Ideas?
  • Any Ideas?
    Bought a couple of 501 led's for the number plate. The fitting is slightly bigger than the normal bulb, but they do fit in and work.
    However, every 3 seconds the bulb flashes, when the plate light isnt on. So obviously, when the car is switched off, the light will flash, very very briefly, but constantly.
    Any ideas? I posted this in general chat also, just incase someone there had any knowledge.
    LED bulbs are generally a pain in the rear for this sort of thing. Have you wired a resistor on them ?
      No, that gonna be the problem?
        i have the same issue, unless you get the slightly more expensive piaa sidelights the normal led's (as they run on a lower current) will flash when you lock/unlock car for a few seconds
        GONE BUT NOT FORGOTTEN!
          Yeah
          LED sidelight bulbs are a bit fussy
          what you want is some of these
          http://www.hids-direct.co.uk/other-products.html
          normal bulbs, no faffing about with resistors and nice white colour.
            Ahh, let me try this, i can handle a flash for a few seconds after a lock/unlock.
            Hm sometimes it flashes 13 times, sometimes 7, cant make up its mind. Nevermind, only cost me a few quid.
              http://www.a-pp.com/shop/piaa_bulbs2.htm
              H151/H91 - W5W 12V 5 = 10W Wedge bulb E-Marked
              Quantity - Pair (are the ones you want according to jay1983)
                Looking at it, thats probably a good shout. Cheers
