Loss of power !
  • Loss of power !
    Hi All,
    Today it seemed to go quite wrong. Accelerating down carriageway, sport button on,50mph in 3rd, fine until...wham, significant loss of power, little yellow spanner and car light on dash between clocks appeared. Went home, slowly and became most miffed. Any ideas, ? Obviously i'll be having a trip to the Authorised Stealers on Monday, but ideas, thoughts welcome.
    Regards
    Daz
    Vauxhall personalities! It happens although I couldnt say why. Bet it is not too major - dealer is he answer - warranty
      Was it cold? Thats all I can think of. If it happens to me when cold it cuts the turbo for around 1 min then comes in again...
        Hi Daz
        This could be a week actuator, it happens after a period of time on some cars, but not all, it could also be a overboost spike when the engine is cold and the inlet charge is dense it can momenterly spike the boost control
        Try disconnecting the Battery for 10 mins to reset the ecu
        If no joy get the car read by a dealer then let me or Tony at VXRPC know the code
        DAP
          Happened to mine only last week....pushing hard in Sport.
          Car sounded like it had a "flame out" surge, power died, rolled onto the hard shoulder and restarted everything was fine. Except for the light.
          Disconnected the battery for a few hours and it was all fine.
          Tested it next day against an M3 and it's going fine!
            Hi All,
            Thanks for your replies, car was warm, 6 miles from home,.i'll give the battery thing a try tomorrow morning, seems to be running ok, except without the power, no noise etc etc, had a good look around, to no avail. Will post the results tomorrow for those interested
            Regards
            Daz
              Mine ran fine after I restarted although the spanner light was on and the sport button didn't appear to work.
              After disconnecting the battery all was back to normal, including the sport button.
              I might add that I'm running the 300 remap full time...even with sport off.
                Hi,
                For those of you in the know, it turns out its code PO234 Boost pressure sensor. Doesn't mean a lot to me but, hey, part ordered and to be done under warranty.
                Regards
                Daz
                  Hi all
                  2nd boost pressure sensor now fitted under warranty after another fault. Thought you'd all like to know. Seems to be a bit of a common problem
                  Regards
                  Daz
                    Well..Well, back in the stealers AGAIN same problem, another one bites the dust. The're getting in touch with the factory for some advice. Not too impressed i must admit
                    Daz
                      PM sent DT
                        share your thoughts sparky!!
                        Daz is your car mapped or standard??
