Oil change question
  • Oil change question
    I'm hoping to do an oil change at the weekend on my driveway as I'm going on a driving holiday next week and wanted to do a quick change which might aid fuel economy a bit
    The last change was done in April, and just for this one-off occasion I was going to leave the filter in place and just do the oil.
    Can someone give me an idea as to where the sump plug is located? I haven't looked myself yet but a hint would be good - and is it just a standard nut as my girlfriend's old renault clio had a funny nut head that only a specialist tool would remove.
    Final question is what oil should I use, and how much allowance should I make for what old oil may be left in the filter?
    The sump plug is located towards the back of the sump but on the bottom. It is usually a T50 torque bit that is required. and you will need about 4 ltr's of 5w30 fully synthetic oil.
      its a torx45 or a 13mm
      off tis2000
      Engine
      Z 28 NEL, Z 28 NET
      Engine oil capacity
      with oil filter
      I
      6,0
      between "min" and "max"
      I
      1.0
      Engine oil viscosity
      SAE 0W-30, 0W-40, 5W-30, 5W-40
