Anti roll bar
  • Anti roll bar
    How do u tell if you have a worn anti roll bar?
    Also would it fail the MOT?
    u would get a knocking noise from going over bumps and yes it would fail an mot mate
    www.themarkwrightproject.org.uk
    www.combatstress.org.uk
      Cheers. I thought it was a knocking sound.
      I have a clicking sound when going straight and more so when turning. Had CVs replaced but still the same? I wonder if it is the inner CV?
        That could be the problem mate.
        Jack the wheels up and see if you have any play in them mate.
        If you have got issue's with the Front arb then it should be just change the rubbers or are they on drop legs??
        haven't really looked at them to what the set up is.
        If it is a inner cv joint I would imagine that that will be quite expensive as there again it may be the shaft and not just the joint like it is on the outer one's I believe.
        HTH.
        Would like to do more,
