zafira vxr heater probs
  • zafira vxr heater probs
    when i put control on for heater it doesnt seem to go where its supposed to like feet and front screen dimist any ideas if its a fast fix or not
    i had the same problem and had to change 1 motor under the steering
      I have same prob too
        You two get ya info down and i'll add ya to Zafira vxr register.....Look on chat about Zafira vxr on forum link
        watoo vxr
        VXR Nothing comes close
          scrap it
          www.themarkwrightproject.org.uk
          www.combatstress.org.uk
            +1 lol
            Arden Blue Zaffy VXR/Standard: Sight & Light/19"/Keyless-entry, Extra added: Stage3 Re-map 285bph/up-rated actuator/Courtney-Sport Pre-Cat/Full Fredrich-Motorsport 3" 200 cell Sports-Cat Exaust/CourtneySport Intercooler/Percys 1.9 Air-Box Replacement/KW Lower 15mm springs/Brake Cooler's/76mm Highflow Top-hat inlet Powerpipe/Bailys DV26/Iridium Sparks/K&N Air-Filter/Pillar-Mounted-Boost-Gauge/insignia Washer Jets/Self-Sprayed-Parts
              Any news with this? I have the same problem.... the direction that works is the one that hits the feet.... air con on feet is freeeeezing!!!
                Could be the cables that operate the adjustment from the control panel they can bend if forced.
                  The levers on the mechanism jam against a lug on the heater box, square the ends of the of the levers off to solve it.
                  North East England - Tech 2 diagnostics/ code clearing available, Cruise control switches supplied fitted and activated . PM me for details
