Wheel Jack?
  • Wheel Jack?
    Does the Zafira carry a jack and wheel spanner. Went to use it the weekend, no jack and no spanner in the rear compartment. Now I am not sure it supposed to be there as there is no sign of a clip for it or anything.
    Has the previous owner had it away.
    thanks
    You don't get any tools or anything with the Zafira. There is however a tyre inflation kit located in the side compartment in the boot.
      Thanks for the reply, I had sussed the inflation kit, still find it odd you cannot take off a wheel.
        Stupid if you ask me. If you get a tyre blow out on you what bloody use is a tyre inflation kit!!
        Got to be a guy that designed that idea pmsl
          unless the puncture was made by a tiny pin and is still in the tyre when you realise it's flat then the inflation kit is useless, as mine just leaked out all over the road, all over the wheel and down my bloody arm but did it stick to the rubber, not a fookin hope. i was glued up like a good un when the tow truck arrived oops:
            if you are to get a jack do not get any of them apart from the Zaf A jack. The normal sideways V type ones will fit the chassis but are not strong enough to fit. The Zaf A has a kind of diamond shaped one or double V type. Cant reallt explain it but it is twice as strong
              Good point mate
                I know what you mean, one pivots on one side only when raising, the other stronger pivots both sides when raising.
                I was gonne use erecting instead of raising
                  yea i thought someone had pinched mine to, till i read the manual. suppose its to save weight and the wheel wouldnt fit underneath with the tail pipes in the way
