What Eibach springs are you looking at as the spring in the picture is for a 30mm drop?
How much are the Eibachs & aren't the Eibachs 15 -20mm drop?
Comes to how they measure and advertise. The normal way is advertising the drop from the standard model height. Because the vxr is already 10 - 15mm lower thats why the drop seems less
Eibach do 2 different springs, 1 being 10-15mm drop, another set (pro) is 30mm iirc
Yeah, there the ones with the height from the VXR height. They advertise them slightly different here in regards to drop, may be an aussie thing?
looks like they only do the pro kit for the Bus. Wish I'd taken a piccy of the DAP springs next to the standard VXR springs. The DAP springs were considerably shorter.... I reckon 30mm from memory. Mind you that is un-sprung !
